About Wifi ???PLS
5 replies · 4,389 views · Started 13 December 2007
there is a question about the wireless in N80 ... i want to know if i can use and connect to the web orginally and can enter all the website's like the PC .???.. and anthor can I write throw the N80 in this Forum and any forum and my subject will added normally.????????.. Pls help ME...:con?:con?:con?:con?:con?
Yes, for post sites you go to it will be the same...
there is the full AAS site here and a mobile one (http://mobile.allaboutsymbian.com)
There are some sites that will recognise you are on a phone and direct you to their mobile site. Either find the link there to go to the full site, or thry a different browser.
kontraband wrote:Yes, for post sites you go to it will be the same...
do you mean if the website don't have redirct i can go and explore the pages normall and pls answer can I enter any forum and post topic and normaly???
the last question can be a different between PC ad phone.???
all the question's relative to WiFi...
well, i am posting now from my n95. No problems. The wifi on the phones act like your laptop connection. Its pretty normal stuff. Most sites you go to will just look normal. Try down load Opera mini. It rocks.
