AS THE TITLE SAYS ABOVE HOW DO i REMOVE ONE OF THESE FROM MY ACCESS POINT SETTINGS.
PS sorry for shouting😉
jedi134 wrote:AS THE TITLE SAYS ABOVE HOW DO i REMOVE ONE OF THESE FROM MY ACCESS POINT SETTINGS.PS sorry for shouting😉
Is it protected because its part of an application... like Boingo??
If so, you need to remove the app first from memory.
Hmmmm right interesting!!!!! how do I find out what application is using it? I`m ot sure as I have lots of stuf on the phone? It won`t be truphone by any chance will it:?
you have to work it out 😉
whats the AP called??
Its called Devicescape, and its a facker!!!:tongue:
Think its IM+ Shape services, may have to delete this application.
yeah, if its devicescape it will be like boingo then... and will be part of the app as devicescape is for roaming wifi access ala boingo..
try removing any app you have like that, .. have a look for the phone icon over icons in Download!
jedi134 wrote:Think its IM+ Shape services, may have to delete this application.
Look in devicescape forums, this has been discussed there and tells you solution to remove it...
