Sim card problem with N95
3 replies · 1,931 views · Started 13 December 2007
Hi
I have a problem with my Nokia N95 phone, whenever the battery runs down or i switch it off, once ive turned it back on it always says sim card registration failed, and i have to take out the sim and re-insert it.
Does anyone know why?? and is there a way to stop it??
many thanx
Dee
I too have the same problem with my N95 and it happens only with T-mobile SIM but never with other sims
What I do is to either change the mode to offline as soon as i switch on the phone or restart it once again if it shows this message( no need to remove sim).
I am unsure about any other cure
HTH
Hi
Yes i forgot to mention that i have a T-Mobile sim. So my phone is not faulty then?? i will try out your tips, hopefully they will work for me. Its a pain to keep having to remove the Sim Card, i find i rarely turn my phone off or let the battery run down.
jatt wrote:Hi,
HTH
I also had that with my TMO SIM.
What solved it for me: upon restart, do not touch it (I mean press any buttons) until it has completely started. If i pressed buttons, it would show the 'Sim registration error'.
Does that also work for you?
Regards,
PM
