Firmware
5 replies · 1,598 views · Started 14 December 2007
You can downgrade but you need to use a 3rd party piece of kit to do it. JAF I think works.
If you don't want to lay out the cash for something you'll probably only ever use once, then figure out what is slowing down your phone and uninstall it.
V20 has no problems at all for me.
Or do a clean re-flash. Remove the memory card (or even format it) then re-flash and DO NOT restore any backups
3Shirts wrote:Or do a clean re-flash. Remove the memory card (or even format it) then re-flash and DO NOT restore any backups
You shouldn't need to reflash, just a full phone format (*#7370#) should have the same effect.
either way, your phone shouldnt be laggin on v20. Was it laggin from the start... or after you installed apps?
