Nokia Channels
5 replies · 2,221 views · Started 14 December 2007
Anybody used this yet ?
http://www.nokia.com/betalabs/channels
downloaded it just to test out how the flip screen thing works using the built in accelerometer, have to say its pretty good,
It flips the screen 360 degrees , glad nokia have started releasing things that use the accelerometer finally
I think for Europe, it has EuroNews and for Africa it has Aljazera.
In a word, one channel per large zone and usually those channels aren't really representative of the region.
Verdict: It's still in it's infancy. It could have had more channels. I think you may be better off getting Sling.
Lynchy wrote:Anybody used this yet ?
which app out is it in the betalabs channel? I cant find any apps that does a "rotateme" style like what you were referring to..
it only rotates the screen within the channels app so it doesnt work with anything else.
cant beleave nokia cant come up with something as simple as this
