Ringing tones for n95 8gb?
3 replies · 2,364 views · Started 15 December 2007
I like to use Mp3 for ringing tones.
Trouble is some of them arnt suitable to i like to cut a snippet out of the middle of the tracks. I have had to convert to WAV in the past and edit down using sound recorder then convert back to mp3.
Isnt there an easier way than this,
anyone know a programme that enables you to cut up Mp3 files?
thanks
Liam
looks good buts its a lot of money just to edit mp3s after the trial runs out. Would have thought there were loads of programmes out there?
Doesnt media player do it as well?
thanks for your reply by the way.. Ill take a look
