N95 8GB Music palyer problem.!!
1 replies · 2,051 views · Started 15 December 2007
Hello guys and gals,
I have a little question for you.!
Last night I transferred 3gb of songs to my N95 and it all went well..
I pressed the 'Refresh' button and the music player found all the songs on the MMS. All good...and worked..
Same this morning...all fine..
Just now when I try to listening the music the music player can only find 13songs instead of the 600 I had before..
So I pressed the 'refresh' option but no luck...
I checked the MMS under tools and file manager and the songs are there..
and if I press them individually they work fine and play starts...
It only seems the music player can not find the songs and do not list them...!!
Any idea why that is..?
Thx for helping me out folks...
TM
My phone won't list the content of certain folders in media player if transferred using mass storage mode (not sure if this is available on the 8gb 95?), it will only see them if copied over using the file manager in PC suite.
If I copy an album folder to the phone which it can't see and then create a new folder on the phone and copy the content of the non working folder to the new one media player can then see the music.
So maybe it's an issue with your folders? :con?
