Tilt sensor n95 8gb?
1 replies · 4,719 views · Started 15 December 2007
do you have to switch this on, i was under the impression when you view a photo if you turn the phone to landscape the photo also turns but mine doesnt?
how does the tilt sensor work and what is it used for in the n95?
By default the N95 8GB's sensor (accelerometer) doesn't do much - when you take (not view) a photo it will auto-rotate the file it produces, but not much else. However, the forthcoming RotateMe application will allow you to do as you say - the screen rotates as you turn the phone. It will be free, but it's not out quite yet.
