withhold caller id
11 replies · 2,672 views · Started 17 December 2007
Does anyone know of a program that will monitor calls made and disable caller id depending on who you are calling, i have the nokia n95 so anything for symbian 60/3rd would be great. thanks.
I don't know of any such software, but you can withhold your number manually by going to Menu -> Tools -> Settings -> Phone -> Call -> Send my caller ID.
With Vodafone UK you can dial 141 before the number and it won't send your caller ID. May work with other countries and networks as well.
If it works, just add 141 to the begining of the number in your contacts.
I seem to remember something called blacklister or summat like that when I had an N80... nto sure if that does something similar?!?!
EDIT>> I was talking about this but I think its aimed at doing other things to the call than what you want to do.
EDIT2 >> Depending on what network you are on you can, as mentioned, prefix dial for the ones you dont want to see your number.
Guys do you know of any free software that will reject ppl who ring with withheld numbers i know of Advance Call manager but sumthin just to reject withheld callers Thanks!!
KingDingaLing wrote:Guys do you know of any free software that will reject ppl who ring with withheld numbers i know of Advance Call manager but sumthin just to reject withheld callers Thanks!!
see the link in my post above for blocking hidden numbers.
kontraband wrote:I seem to remember something called blacklister or summat like that when I had an N80... nto sure if that does something similar?!?!
I think I'll get a copy as I sometimes have problems with nuisance calls. I had a program on my 6600 and N70 called Blacklist which would block calls for me too, but the person calling would hear the phone ring once first before it went to answerphone.
Has anyone got this new software that kontraband mentioned and know whether the same happens to that too?
kontraband wrote:you can always try asking [email][email protected][/email] that question if you cant find any users here quick enough. 😃
Thanks. I knew the email address was on there for help, but I didn't want to ask them as they'll probably just say "Oh yes, it rejects these calls immediately". I wanted to ask users of the software, those who will give me an honest answer.
Actually I have my answer now. I feel so silly. 🙄
I downloaded a 15 day trial of the program from the page you provided a link to, called it by withholding my number with my landline, and all I heard was a click and then my voicemail.
In future I'll check for trials of software before asking questions :redface:
zxon wrote:Actually I have my answer now. I feel so silly. 🙄
LOL... so long as you get your answer... its cool! 😉
