Anybody got any good video/dvd converters?
29 replies · 4,904 views · Started 18 December 2007
Hi Has anybody got any good dvd/video converters that actually convert the whole dvd to the phone, rather than sepaerate vts files ? ie id like to watch all the way through !! Lol, and what do you use? and hopefully dvd watchable quality on the phone with correct settings etc to encode for above..
Hope somebody can help
Thankyou
Hi there,
well, there is always slysofts clonedvd mobile... have a look at www.slysoft.com . It is a little expensive, though but kind of a one shot solution.
Many people here like 'Super' a lot, it is a great and free encoder ( www.erightsoft.com ), but you still need something to rip the dvd...
I am personally also looking for a simple solution, have not found one so far.
Best regards,
PM
Hi and yes i will try that, i actually ue nokia video converter at the moment, it does rip the dvds straight into mp4 and not bad quality, but as with you im also awaiting a good quality dvd to mobile that is actually dvd quality..
Sure there is something out there..
Thankyou for your help
Brian
SUPER converter is the best - really.. Free and converts into just about every format available under the sun
Me neither, lots of text saying click on link but no download link...
As I have said before (for the benefit of people who search :rolleyes😊 DVDDecrypter is best for ripping (and free) and Super for converting. Super's website is a bit of a pain but it's designed to generate several clicks and thus revenue from advertising. That direct link will stop working soon as they move the installer around to avoid direct linking (which bypasses their revenue generation).
It's kind of annoying but I see why they do it and it is a great program so I don't mind a few minutes of hunting to find it!
EDIT: Just tried your link and already it only goes to the site, not the download. Just go
Bottom of the page 'Start Downloading
Middle of the page 'Download and use'
Bottom of the page 'Download super setup file'
I still use media coder, its free and brilliant
cant be bothered with a link so just search media coder in google 🙄
I'm sure I've said it before too, but for a one stop, easy option, AnyDVD with CloneDVDmobile has to be the easiest method of ripping and converting from DVD to mobile in one operation. But you have to pay 😊 Having used the free options, I chose to pay, and was glad of it.
Hi, so is clone dvd to mobile realy exelent quality compared to super ? and just need to no before buying the clone dvd mobile..
Thanks from Brian
Depends on what you mean by quality. The final video quality is no different, it's more about the journey to that point! Super is a general purpose converter so need more fiddling to get the settings right for your phone. Mind you, once you do, you can save the settings to a profile and reuse them evertime.
Get handbrake if you have a mac, it's dead fast and easy. Does the whole conversion in one go.
If not, then I too recommend Super for the pc, i've used it and it works good.
readbmr wrote:Hi, so is clone dvd to mobile realy exelent quality compared to super ? and just need to no before buying the clone dvd mobile..
CloneDVD mobile + AnyDVD: put DVD in drive, press button, wait short time (it's quick), output file ready to transfer to N95.
Super: Put DVD in Drive, run a program to rip files from DVD into format suitable for conversion. Run Super to convert ripped files into format for transfer to N95.
Oh, and with Clone, you can now copy BlueRay films as well....(though obviously the output quality won't be the same 😉 )
Thanks from Brian
Hello,
Just thought id mention that with clone DVD the audio is slightly out with the video. However the quality of video is excellent and ease of use superb
Crispy
still struggling to find super. Which links to i need to click on to get them their advertising funds??i want super as i want something that will make great vids to watch on my n95.
will nokia multimedia convertor 2 do the same?
Ok then , has anybody got their settings for converting videos to the n95? and awesome quality would be great. also i have downloaded clone dvd and its not bad, just wondering if you can alter the volume settings to make it louder when playing on the n95 as the ringtones seem louder if you no what i mean, anyway settings please for what you guys use on super ...
Look forward to seeing your conversions and reviews, this thread could help lots of us n95 users for video playback..
Cheers
readbmr wrote:just wondering if you can alter the volume settings to make it louder when playing on the n95 as the ringtones seem louder if you no what i mean,
Again. Don't have a problem. Volume is loud enough for me. Certainly too loud for comfort with headphones at full volume. Cant give settings as currently on my N95.
Have you guys ever tried the Winmenc? I've been using it for video converting with great quality. It supports DVD as well. I can use it to convert the video to X264 quality.
:icon14::icon14::icon14:
I'm not sure if this helps but I use xvid4PSP and it's a great converter. I'm sure that it can convert for cell phones because it has a specific iPhone mode.
readbmr wrote:Ok then , has anybody got their settings for converting videos to the n95? and awesome quality would be great. also i have downloaded clone dvd and its not bad, just wondering if you can alter the volume settings to make it louder when playing on the n95 as the ringtones seem louder if you no what i mean, anyway settings please for what you guys use on super ...
Cheers
The settings I use to convert to N95 are:
Output video = H.264/AVC
Output audio = AAC
Video scale size = 320:240
Aspect= 4:3
Frame/Sec = 25
Bitrate = 384
Hi Quality, Stretch It, 48k Audio
Sampling Freq = 44100
Channels = 2
Bitrate = 64
That is for playback on the N95 with no third party players. Gives good quality and reasonable file size.
If I want to output it to TV I usually go for avi (the Super defaults) and select 'all divx players' then use the symbian divx client.
What I usually do is use a video editing program, say like Adobe Premier or powerdirector and crop the movie or raise the volume of the file. Then I use Super with output settings as MP4, none of that h.264 stuff. I keep the FPS the same as the original file, so if it's a dvd movie, i keep it 29.97FPS.
If you have DVD shrink, you can author the disk and have DVD shrink save just the movie file to your hard drive, that way you don't have all the previews and other crap that would make the movie a larger size. You can also save just the 2channel audio track which will also make the size smaller to save, just unclick all the 5ch tracks and the other language tracks other than english.
Hope that helps.
I might give CloneDVD a try, I've got Super now and it is...super, but I like the sound of the ease of use of CloneDVD.
Hi, has anybody got all thier setting that they use with Super ? ie birate/etc and what do you all thnik of super compared to Clone dvd, i think the audio quality is a little lower than the Super Software, Please lets have your opinions etc and settings please for Super ?
Many thanks from Brian
readbmr wrote:Hi, has anybody got all thier setting that they use with Super ? ie birate/etc and what do you all thnik of super compared to Clone dvd, i think the audio quality is a little lower than the Super Software, Please lets have your opinions etc and settings please for Super ?
Dude, did you even read this thread?! I gave my settings 2 posts above yours 🙄
Hi DUDE !!!!!!! Yes of course i read this forum ? but want to no your settings for super converter if thats no problem, ie video codec/birate/audio birates etc, do you read this properly dude !!!!!!!!!!!!!!
oops sorry and yes its me thats blind and take full responsibility for my posts!!! sorry i will read properly in the future, merry xmas merry xmas !!!! lol, and thanks guys..
Hi and yes im truely sorry, god now i feel realy bad, not like me to be lazy and not to read the entire posts !!!! lol, many thanks again and i will try those settings, would buy you a pint if you were nearer to me ! lol, thanks again and Sorry ....
