i have the p1i but i have forgootn the phone lock which i have set is there any way too recover the fone lock or too reset the fone so the phone lock goes away
forgotton phone lock on p1i how to recover it urgent help needed
Use XS++.
you mean type XS++?:frown:
Hi There,
If you google for a program called XS++, then run it and connect your phone (using the onscreen prompts - remember to use smartphone connect) it will tell you the phone lock code during connection in the left hand window.
Richard
