Which access point is my N95 8GB using when a modem
1 replies · 3,639 views · Started 20 December 2007
Hi people. I have a question regarding the use of my N95 8GB as a modem.
What I've done is just set up a dial up network in windows using the n95 as the modem for the connection and put in the number to dial as: *99#
This all works and I get onto the web and can surf no problems.
The one thing I am wondering though is which access point is it using? Vodafone have got lots specified (such as wap, internet, mms, email etc...) and I need to know which one is in use.
Also, more importantly, how do I specify which one it should use?
Thanks for any help you can provide,
Paul.
Hi Boomah,
The access point you use depends on what you have set up on your phone. To find out which one is set please follow the steps below:
1. From the main screen tap the menu key
2. scroll to tools press the centre key
3. scroll to settings press the centre key
4. scroll to connection press the centre key
5. scroll to access points press the centre key
The access point that is in use will have a dot next to it. You can also change your access point in the same section by simply selecting another.
All that the access points are are methods of connecting. We usually recommend using Contract WAP.
Hope this helps,
edwardpeter
Vodafone UK
