face warp n95
3 replies · 5,680 views · Started 20 December 2007
i downloaded the trial version of face warp but when i try to install it on my n95 it says that it is not supported?????
Are you sure it's a S60v3 app? The only versions I've found are for v2
pennas wrote:It's a java app, I think
It is a Java app and 1 version works on almost any Java enabled phone, google is your friend, I would post it but im not sure if its free 😊
