Hello
Due to the last software upgrade (before v20) i kept having phone freezes, so had to keep takint the battery out.. Now all the 3 clips have come off meaning the battery cover sometimes comes away... do nokia sell replacements? it not, where can i buy one? its really annoying!
Here you go - http://www.mobilefun.co.uk/product/13217.htm
They have the sand one as well if you need that.
�7.95!!! bloody expensive for a bit of plastic!
oxfordmark wrote:�7.95!!! bloody expensive for a bit of plastic!
i'll sell ya a black one for �5 or a flip paint one for �7?? but ur prob after a plumb one , which i donthave? lol😊
Why would you not take it back to an authorised nokia repair agent and get it replaced under warranty?
The little clips holding the battery cover on my N95 went in exactly the same way and it was replace under the warrantly.
The way I see it, if the plastic of a component that is designed to be removed and replaced repeatedly fails in this way, Nokia should (and do) replace it.
