Hi there,
Just after some advice regarding my N95 and E50 in relation to handsfree Bluetooth usage and am hoping for some expertise beyond that of Nokia 😉
I have just put an order down for a brand new Seat Leon with the integrated Bluetooth kit that I have paid to have as a factory option. This incorporates, if you're not familiar with it, a Bluetooth sync with the car for making/receiving calls, controlled via the steering wheel, and also a rather neat integration of the phonebook contacts, missed, received & dialled calls, all controllable on the dashboard.
Since doing so it has come to my attention that neither of my phones, the N95 or the E50, will properly work with the car and that the phones will not synch phonebooks (though they will operate as normal handsfree kits, controllable from the phone). This is a big disappointment to me as I have spent a great deal of money on both the car and the phones only to find the Symbian phones are not supported. Is there any software I can use with the phone to make it work, official or not? Is an update being prepared as it seems to be a very common problem and a big disappointment to many customers. The Seat Leon (and most cars with integrated Bluetooth it seems) owning world is certainly craving something to be done about this.
I am also disaapointed to find that my old Nokia 6230i (that I have now given away in favour of keeping the N95) WOULD work perfectly with the kit. Is this an operating system issue with the Symbian software that the N95 and E50 run on? How can Nokia's entire range of latest phones be moving backwards from the previous generation?
I sent an email to this effect to Nokia today and received the following suitably wooly response:
Dear Rob,
Thank you for emailing Nokia Care.
In response to your enquiry, we have tested our phones with accessories manufactured by Nokia. As such, I am unable to confirm the compatibility and operability between Nokia products and third party manufactured products.
I would recommend that you explore the compatible car kits for Nokia N95 and E50.
The compatible car kits for Nokia N95 are as listed below:
1) Nokia Bluetooth Display Car Kit CK-15W.
2) Nokia Multimedia Car Kit CK-20W (you may use the supported handsfree mode).
3) Nokia Advanced Car Kit CK-7W (connection via bluetooth)
On the other hand, Nokia E50 is compatible with the following car kits:
1) Nokia Wireless Car Kit CK-1W.
2) Nokia Multimedia Car Kit CK-20W (you may use the supported handsfree and navigation modes).
3) Nokia Advanced Car Kit CK-7W (connection via bluetooth).
With regard to a software, please note that there aren't any available to enable the compatibility between Nokia products and third party manufactured products.
However, I will certainly forward your feedback to the relevant department for future consideration.
Kind regards,
Bhanu
Nokia Care
If anyone has any idea on a way around this, I would greatly appreciate any input.
Regards
Rob
