Annoying Blue flashy~ thingie~
7 replies · 3,473 views · Started 21 December 2007
I don't like the annoying blue flash which the phone makes every second or so when it goes to sleep mode.
How do i turn it off?
thats if you can?
I think that you can't do any thing about this little flash ... From my sight I think it's lovely and not bad ..... I don't fill it...
No , seriesly I think you can turn off the light without the mentioned way's .. you have to enter into your phone there is "sleep mode" and turn off .... but this mode is made to be good for the battrey to Hold on for a while... by turnnig off the mode you will take from the battrey some power
Thankx...
Kelwa18@gmail wrote:No , seriesly I think you can turn off the light without the mentioned way's .. you have to enter into your phone there is "sleep mode" and turn off .... but this mode is made to be good for the battrey to Hold on for a while... by turnnig off the mode you will take from the battrey some power
Thankx...
If you do a search you will find this has been discussed extensively here, as many other things .. so search first.
Briefly FYI the blue flashing light is an indication to you that the phone is switched on and in sleep mode, as there is no other way to tell if the phone is on or not (no other visible lights).
To stop the light flashing ... just plug in your charger
