Route 66 Maps problem
2 replies · 2,498 views · Started 22 December 2007
Hi, does somebody know where should put the maps, I already installed the software but i don't know where to put the maps, my map has a .PRM extension, i own a N95 8GB. Thankyou.
E:\System\Apps\Route66\Maps\
Create this folder if it doesn't exist.
If you can't see the System folder on the memory card, either connect with mass storage and type it into the address bar (it's a hidden folder), or use Y-Browser. Merry Christmas!
imdaShiy wrote:E:\System\Apps\Route66\Maps\
Thankyou very much, you saved me, im leaving tomorrow in a trrp, and i will really need it, thanks.
