does anyone know what the icon stand for ?
when u use video mode...there will have 'hand' icon on the right :con?
hippo1n2 wrote:does anyone know what the icon stand for ?when u use video mode...there will have 'hand' icon on the right :con?
Read your manual. !!!!!
I had the same doubt, it�s a "video stabilisation" option, you can enable/diasble it in the options menu.
The icon is not refered to in the manual.
lhip wrote:I had the same doubt, it�s a "video stabilisation" option, you can enable/diasble it in the options menu.
Funny .. in my manual it is explained what it is
Page 26 under "record video" section, icon numbered 4 on the picture.
You can download a manual here if you dont have one
http://nds1.nokia.com/phones/files/guides/Nokia_N80-1_UG_en.pdf
