3rd Party Applications
4 replies · 3,113 views · Started 22 December 2007
Unlocking my phone for 3rd party apps, I know you have all probably heard this before but im struggling to open my N95 8gb for 3rd party apps im getting certificate error messages, ive tried Symbian Signed and FExplorer with no luck whatsoever, please can someone throw some ideas or solutions my way. Thanks in advance for all who reply. 😡
Hi pearce
First thing you need to check is go to App manager open it then choose options, then settings and check that Software installation is set to All and Online certificate check is set to off.
That should help but with some apps there certificate is now more than a year old so has expired so set your phone's date back a Year and then after successful installation set i back to the correct year.
I hope that solves the issues you have been having.
Marc
Or look at the timestamp of the signed file and set your date accordingly on your phone, then install 😊 No need to resign.
There is a handy little application called "Mobile Signer" from www.opda.net.cn - works as advertised and saves loads of time, can sign things directly on your phone.
Edit: Reading Chinese is probably handy for the above link. Or you can get it from http://www.symbian-freak.com/news/007/12/mobile_signer_freeware.htm though I think this is a slightly older version that doesn't quite work, look for V1.03
