transfer data fron clie to ericsson P800
4 replies · 3,008 views · Started 26 January 2003
How to transfer calendar data from sony clie to p800???
could someone :evil: help me...
thanks
You have to sync your Clie with Outlook (which I did) or Lotus. To do this you have to first reinstall your Palm software for Clie and select the sync with Outlook option. Intellisync Lite will then be installed. Once the installation is complete sync your Clie just as you did before. Once all the information is in Outlook you can then sync it with the p800. Make sure you make a backup of your data before beginning any of this.
One quirk - if you have 2 identical phone number fields (e.g. work) both numbers will be put into one field in Outlook. I think this is an intellisync problem and would appreciate any help to try and separate this information.
Good luck!
Good luck!
Good luck!
If you wanna read on how to migrate the Address Book from Palm to Outlook I posted instructions after getting it done yesterday.
I think this also works for Clie and it solves the problem of the merged contacts fields that the previous poster mentioned!
Well if you wanna read my horror story of sync attempts with Outlook here's my full post: http://www.allaboutsymbian.com/phpBB2/viewtopic.php?t=12972
I posted full instructions on how I did achieve to migrate my contacts (address book) without using Outlook!
