can someone please sign rotate me 2.0 beta 5 for me please it would be apriccated
16 replies · 16,351 views · Started 23 December 2007
please can any 1 sign rotate me 2.0 for me
i have a nokia n95 8gb
my serial is :356983010425046
please tell me if u need any more information
I have a similar problem I want Rotate me Signed but want to do it my self! Is there an idiots guide? A real idiots guide?
I use Tiscali and Symbian seem not to like that mail address. any other adivse?
Why do symbian promote self signing where it is desinged to be signed by hackers only!
best
Gerrit
gerrit wrote:SNIPPED
best
Gerrit
What you on about??? Why is it designed to be signed by hackers only??
There are a variety of idiot guides around on the net... and many of the posts here have links to them... search it.
kontraband wrote:What you on about??? Why is it designed to be signed by hackers only??
Sorry to make my self clearer, I thought I had a reasnoble amount of knowledge on computing and phones.
If self signing is meant to be user friendly... it is easer to get some Pirate software than to self sign.
I read this site to keep upto date with software develoments. I do not wish to waste hours instaling software on my phone..
Happy Christmas
Gerrit
I have a different problem, I signed my rotateme through symbiansigned.com, but when I try and install I get an error (constraint by certificate). any advice?? anybody else with the same annoying problem??
Thanks zxon for the file but while installing the file it gave a "constraint by certificate" error... how do i proceed???
Thanks again...
zxon wrote:Just download the file with your username on it and install on your phone.
Neither of the files have your name on it so why did you download them? :rofl:
Seriously, the reason why you're getting this error is because the app you're trying to install has been signed to a phone with a different IMEI to your own.
Giving out your IMEI on an internet forum is no big deal. Your phone isn't suddenly going to stop working because someone else is using it in their stolen handset. You can't just randomly get IMEI's blocked either, at minimum it takes proof of purchase, more frequently images of the box and identification stickers, as well as a recent police report.
If you want to be a little worried, think about this. I can pull up to almost any cell site with bog standard off the shelf equipment and suck down tens of thousands of IMEI's, IMSI's, text messages, phone conversations, plus a whole lot more. It's as simple as having a Parabolic dish, a spectrum analyzer, down converter, modem, a digital capture card, and a computer less than about 5 or 10 years old. Programming skills sold separately.
Encryption exists between your handset and the cell site, it does not usually exist anywhere else in the chain. CCITT 7 is easy, GSM vocoders are simplistic, stripping out packets on modern hardware, all of this can be done in practically real time.
What is significantly more challenging is the signaling system, it is out of band, sometimes not even in the same transmission. While it is (sometimes) fairly straight forward to know who is calling who, it is quite a task to find the specific voice slots associated with that information. A few extra million dollars are required to have a holistic solution.
Just wondering if you can sign the rotate me beta 5 for me. I would really appreciate it. i wont post my imei number here, can i email it to u.
steve
dchky wrote:It's as simple as having a Parabolic dish, a spectrum analyzer, down converter, modem, a digital capture card, and a computer less than about 5 or 10 years old.
Haha, that's awesome. You might as well say it's as simple as brain surgery or rocket science!
can you signed rotate me V.2.0 beta5 for me also ?
my IMEI No. is : 354835018007196
thanks in advance
any1 can sign there own apps at symbian signed ,If you've got the correct file it's so easy.
the guy who say's he signed his file but it wont install go to
app manager> settings>Software installation and put it on all then make sure Oline certificate check is off and try again,if you have a file signed for your IMEI then it should work now
Hey I'm struggling to sign my rotateme aswell..
It seems SymbianSigned have made it harder to do so... Every time i try i get this message..
"Request DevCert
Your request has failed. Reason:
-Developer Certificates will be ENABLED for users who have a Publisher ID ONLY
-ONLY if you used a Publisher ID to create a .csr file with the DevCertCreate tool will you be able to use Open Signed Offline to create a Developer Certificate.
-Developer Certificates are currently DISABLED for users without a Publisher ID. Users who DO NOT have a Publisher ID CANNOT request Developer Certificates or use Open Signed Offline.
-If you have recently obtained a Publisher ID and are unable to create a Developer Certificate using Open Signed Offline please request support through the Symbian Signed forum on the Symbian Developer Network here"
So can someone please sign rotate me for me... Thank you in advance...
My IMEI is: 359542012755615
