New: EDoom for P800 - play Doom on your P800
11 replies · 26,630 views · Started 26 January 2003
Thanks to Peter van Sebille Doom for the P800 is here in the form of EDoom. The port is supports, game save/load and it has 8 channel sound support and can be configured to either rotate the screen to the left or right. See the full story for some screenshots and more infotmation. Oh and did I mention its free!
The game can be found here http://www.yipton.net/
On this site you will fin information about the controls and the wad files needed to run the game.
i have downloaded and copied the doom1.wad and doom3.wad to the edoom directory but still when i run the game it comes up saying 'Main wad file not found' am i doing something wrong?
There are 2 wad files: doom1.wad which is about 12mb big and doom3.wad which is just a bit less than a megabyte.
You have to create a 'DOOM' directory in your documents folder (it has to be on your memory stick because the phone doesn't have enough memory to hold the wad files. Then you copy the wad files into that directory.
The game is difficult to control and its hard to get used to, it's great for showing off though 😊.
[quote="mauru"]There are 2 wad files: doom1.wad which is about 12mb big and doom3.wad which is just a bit less than a megabyte.
[/quote]
That is not entirely correct. The doom1.wad file, shareware version, is about 4MB, and the full version: doom.wad is about 12MB.
The 'DOOM' directory will be automatically created once you start the edoom.sis file.
I download domm1.wad to /documents/doom & when i wanna run this game on my p900 its not working. "running doom" & its all. what is wrong?
I have a Motorola A925, I have installed the P800 platform (i think i did that properly) and then I have ran and installed edoom. Now I am getting the error:
Program Closed
Program Main
Reason Code ECompXL
Reason number 33
I am not sure if I have put the wad files in the right directories. If anyone out there has had total success making this game work on an A925 email me at [email][email protected][/email] how you did it.
THANKS
Where can i get the doom1.wad and doom3.wad files?
i have looked all over the net and havn't been able to find them.
For all of you who are having PROGRAM RUNNING message displayed when trying to run the game. I had the same problem until I realized that its a simple solution creator failed to mention.
You have to make sure that BOTH Doom1.wad AND Doom3.wad are in the DOOM folder under documents either on your Stick or Phone. One can be in each, doesnt matter as long as both are present.
Sincerely,
Tim Nikolaev
