LINE2 FIX !
I updated my standard N73 software to the new ME v4.0736.3.2.1 software and lost my Line 2. I need this for work ... Is there any way I can get it back by downgrading the software ?. The updater say I'm at the latest version regardless of the product code I use.
UPDATE !!!!!!!!!!!!!
Found solution ....
If you install MobiMB demo and NKProfile V3 - there is a check box for ALS, Check this and line two is enabled - You can't use the # keys to toggle betwwen the lines as before but you can go yo the phone Call menu and change it on there.
Hope this helps ...
