N95 please Someone HELP??
3 replies · 1,546 views · Started 26 December 2007
Sorry to shout but Im really stuck.
I Got a n95 from my local TMobile/nokia service centre (Essex Cellular) had it approx a month. A great phone .... until I downloaded fring. From this point it quickly went down hill!!!
It started not to respond to the numbers being pressed also would restart if I pressed numbers!! so I could not use phone!!
Took it back to the shop and they advised to get a new sim card, did this still the same. Went back to shop they exchanged phone. I said just download telephone numbers. They said come back. When I came back the chap I spoke to was busy another chap nid the transfer of data. He downloaded the whole lot. Unfortunatly I did not check the phone as I was in a hurry. later I found the new phone had the same problems!!
Cut to the chase!!!
How can I sort this out!
Do I need to flash the firmwear?
Do any of you guys know what this is??
is there a solution do I need a new phone??
Sorry if this is a stupid post .... Im a nubie to this thread and the n95!!
PS sorry for the length of the post!
You can hard reset your phone by doing *#7370#
This will wipe everything on the phone but will make it just like it was as you got it.
Or you could just uninstall fring from the manager Tools / App Manager
Thanks for the swift reply Quakester2000 but when I press any key on the key pad it resets the phone almost like a mini restart!! so I cant use the key pad also when I go to applications to restore factory settings it ask me to say tes or no when I press yes nothing happens!!
Can anyone Please help!!
Richard
:frown:
You can reinstall the firmware by downloading nokia software updater from the nokia website. If you have another phone make sure you have a copy of your contacts on the sim as it will wipe everything. Or if you are able to, sync with pc suite first
