W960i & WLAN (WPA/TKIP)
9 replies · 29,944 views · Started 27 December 2007
I am unable to get WLAN working on my w960 with a D-Link DI-784 using WPA/TKIP.
I am sure that all needed information to get it working is correct (SSID and password), and I have two laptops with identical configuration that successfuly connect to the D-Link with the same configuration.
Are anyone getting the above to work?
Regards
-b.
I have verified that "64 bit" WEP is working with the w960i, but I can't use that due to security considerations.
-b.
128bit WEP works too. Haven't tried WPA, but I think the phone should support it.
However, it only has 802.11b (ie 11Mbit/s) support, not the 56Mbit/s 802.11g. Perhaps you're running your WiFi in g-only mode?
cirrus wrote:128bit WEP works too. Haven't tried WPA, but I think the phone should support it.
I also tried WPA but it didn't work. And my router run in b-only.
The question is, that the softwer or the hardwer is the thing that dosen't support the 802.11g?
Well i am using wireless-G 2.4 GHZ braoadband router i use b mode only not mixed mode but my w960i still unable to find wlan device :S im really upset is it fault of my set any idea guys?
I got my W960i working with WLAN using WPA-PSK. Initially tried and it failed miserably. My broadband router is an O2 branded Speedtouch and has the option for "Legacy" 802.11b/g, as well as 802.11b/g. Changed it from standard to legacy and voila! Am happily surfing via the WLAN.
Am not sure what the diff is between the legacy and standard 802.11b - anyone care to enlighten? But that definitely worked for me...
S
I personally went through frustration trying to connect to the internet using WLAN. I'm using Linksys as my router by the way.
I found out that the reason why I couldn't connect to the internet was because of the SECURITY during WLAN Setup. I used WEP as my security before. But when I changed to WPA Personal, and setting to TKIP for Data Encryption, it worked! I'm not sure if it might work for you, but why not give it a try. 😊
I can confirm it is fully working with wireless mode set to B only. when I set it to mixed, it does not work.
linksys wrt54gs running dd-wrt.
hope this helps.
Hallo nutze die ASUS WLAN 100g Karte um die Verbindung mit meiner FBF 7050 herzustellen neueste Firm.
Box auf TKIP
Das funktioniert auch ganz prima wenn ich an der Karte WPA-PSK und TKIP einstelle.
Stelle ich jedoch an der Karte und Box um auf AES wird der Zugangspunkt nicht mehr gefunden.
DIe Karte bietet folgende Einstellm�glichkeiten
open
shared
WEP
WPA-PSK
WPA
Trage ich an der Karte nur WPA und AES ein fordert er eine Identit�t ID mit Radius Server ?...
An der Box hingegen kann man nur von TKIP auf AES WPA2 umstellen - was anderes ist hier nicht zu finden.
Jemand eine Idee was ich probieren k�nnte...?
Danke
Ach ja OS ist WinXPpro SP2, ich nutze die ASUS Software neueste Version heute runtergeladen nicht die XP eigene.
