how to turn off voicemail on o2 (UK)
12 replies · 43,643 views · Started 27 December 2007
A bit off topic but i am not able to turn off o2 voicemail. I have tried dialling 1760 but this doesnt work. I have an N95 and am on o2
any help would be great
thanks!!
i have n95 and dialled 1760 and it has switched my mailbox off!!
thats crazy. i dont understand why mine disconnects then !
Mine says "Note: active diverts" and then disconnects the call.
do you get active diverts msg too ? Maybe this is preventing me from disabling voiemail.
ok ive turned off all diverts to voicemail through the n95 options menu ... finally !
1760 still doesnt work but atleast voicemail is off now.
thanks
nudda wrote:A bit off topic but i am not able to turn off o2 voicemail. I have tried dialling 1760 but this doesnt work. I have an N95 and am on o2
thanks!!
What were you actually dialling ?
Have you tried 1750 to turn it on yet ?
You might find 1760 successful after that.
Just a thought.
you coulda just disabled it via the cancel divert setting on the phone if your 1570 didnt work??
coool! *sorry if you mentioned that above... was skim reading! 😉*
