emTube hits 1.04
7 replies · 5,200 views · Started 28 December 2007
We don't normally news post version updates, but emTube is such a biggie. v1.04 of the best native YouTube client for S60 includes a simplified download and install, interface tweaks, bug fixes, an Italian language option and a flv recogniser (this bit needs self-signing though). Highly recommended for anyone with a Wi-Fi capable smartphone.
What does the flv recogniser do? I tried searching from emTube site but with no luck...
=)juha
emTube playback seems better than tinyTube. Steve, if you know of a better one please tell us. You hinted there are others?
ps. Please tell us with a future fw upgrade E90 will have tv-out.. Pleease! Streaming from pc to phone (N95 fw update) sounds so neat, too. I want some of that on my brick!
Happy Holidays! 😊
how do i play downloaded videos? they are saved as .flv, so how do I play flv's? I tried Flash Lite 3, but it cannot recognize/find the file in its file browser.
Hi all,
What a great app that simply does what it says and if you install the N95 version it takes advantage of the inbuilt accelerometer with no need to install anything else or having to sign it. Just does what is says it will with no fuss. Although i always wait for the download to complete which over WiFi is fast and then suffers from no stuttering or lag and the automate function works nice and smoothly to. The developer deserves a donation for a completed app as it's not a Beta that you have to donate to be a tester who knows what he will come up with next if rewarded for his completed app but much prefer his marketing to some others i won't name.
Marc
Theres an update(v1.06) are available right now.
Changelog:
New: Added French, Turkish, German, Lithuanian, Hungarian and Danish translations.
New: Added two new keys in player view: 3 - rewinds video and 4 - mutes audio.
New: Added "User defined" option to the max search results, it allows to enter any value from 1 to 999.
New: Added �User video� and �Related videos� options to the play view. It is now possible to display list of related/user videos without going back to the search results list.
New: Seek bar on full screen now shows how much of the video has been downloaded (using red color).
New: emTube now remembers position on the search results list when user finishes watching video and goes back to this list.
New: Added muted audio icon. In both normal and full screen mode.
Fixed: Several bugfixes that improve application stability.
Fixed: Access point selection dialog now shows BT access points, so it should be possible to use emTube if user connects to the internet via GnuBox.
Fixed: Audio volume handling, was set to 0 even if there was one bar visible.
Fixed: OSD pause indicator was sometimes visible during playback.
Fixed: Video titles are not correctly scrolled using marquee effect on search results list.
Fixed: emTube is now compatible with rotateMe 2.0
Go to : http://www.emtube.yoyo.pl/emTube_S60_3_0_v_1_0_6.zip (with PIPS)
http://www.emtube.yoyo.pl/emTube_S60_3_0_v_1_0_6_noPIPS.zip
