N95 8GB Please Help !!!
3 replies · 1,436 views · Started 28 December 2007
Hi All,
I have just recieved my new Nokia 8GB.
I connected the device to the nokia Pc suite and tried to search for an available update for it.
All was fine up to now. The new software downloaded successfully to my pc via the nokia software updater. I was waiting untill the software update get finished. After a while before the software update done it asked me to remove the battery charger from the phone and insert the pattery again and reconnect the charger after all i have to hold the power button for few seconds and release it. Finally i have to click on Retry Button shows in the Nokia software updater. Once again it begin running the same process with no succeded software update and I still get a white screen with no Nokia labels or whatever else.
Any help will be appreciated.
PLEASE NOW !!!!!!!!!! because i still have it on connect to my Pc via the USB cable.
Now i can tell what kind of help all can get from this website.
After 4 days of waiting and more than 105 viewers there is no single reply!!!
Thanks all and i wish you a very happy 2008 😊
I am confused you said the updater finished? like done updating? Anyway a white non responsive screen is BAD, you might want to take it a Nokia Service centre because it sounds like you bricked it.
If it opens up afterwards then you didnt brick it.
Make sure that you a SIM card in and you have the phone set in the General Profile.
And I've been in this forum for a while and I think everyone does a GREAT job, people dont respond because They simply dont know the answer.
It is probably likely nobody answered because this problem has been discussed many times already. There are several solutions, reset the phone using the power on method, dead flash with Phoenix, take it to a market somewhere and get the shifty looking phone repair guys to do their magic, or go to Nokia and say it fell apart in my hands chief.
Happy new year to you too 😊
I guess this link will be a good starting point.
http://www.allaboutsymbian.com/forum//forum/thread/66146/&highlight=dead+nsu
There are many more like it.
