where are back up files saved on my pc? (PC suite)
1 replies · 2,112 views · Started 28 December 2007
as the title really, I cant find them on my pc. I know you have to make some files unhidden to view the back up ones, but cant remember where to look..
Liam
Just go to do a backup, and it shows you the path of the saved file, which for me is:
C:\Documents and Settings\Tony\Application Data\Nokia\ContentCopier
Content copier also has a "scan PC for backup files" which I am sure would point you to where they are stored.
Regards
