hi all,
i installed gnubox for s60v3 on my 3250 and found a vid on youtube how to set it up properly for the phone to be able to connect to the pc via the bluetooth
( http://www.youtube.com/watch?v=asbMsxQnTbw )
my bluetooth software is BlueSoleil, latest edition.
then i created an Incoming Network Connection and tried to connect the phone and voila it did! next to the Incoming Connections, which now says "1 client connected" (i can not tell you how i jumped off my seat when this happened, this was the first successful connection after a dozen attempts :rolleyes😊 on my Network Connections window is a new connection entitled "<unauthorised user>" and when i click Status it tells me that the connection is at a healthy speed of 1.2kbps 😎
now my problem is, the phone then starts to load the homepage and after some moments it reports "Services: no gateway reply".
NO surfing / browsing etc :con?
seems as if Windows is the problem isnt it, im guessing that windows is acting as gateway..
so i am asking some of you networking gurus😛cguru: if you can help me in this little project..
i would REALLY REALLY appreciate any help / thoughts / workarounds
if you want i can describe the whole setup process in greater detail
