2nd question in as many minutes 😊
got an E70, i chose it for the wifi and the qwerty keyboard, so i could get my e-mails for free and maybe search things about the town im in when i am touring europe, and find a wifi spot i can use, stuff i'd have used the pocket pc for, but i want to cut down on the ammount of expensive electronic gadgets i have in my pockets.
but the built in wifi finder on the E70 is a bit naff, it seems to have a refresh rate of 1 minute, that's be ok for a desktop computer, but not for something that is designed and sold to be used whilst your mobile,
i've read somewhere there are a couple of free wifi finder apps for this phone, one of them is that psiloc, which is still naff, as it's minimum search time is still 1 minute,
but i can't find the other wifi finders now i want one, on my laptop i use 'wirelessmon' it's really a wardriving app. but it cab be set to scan every millisecond if you want, gives a list of all hot spots found, shows if they are open or enxrypted, signal strength and so on, and allows you to connect with one click,
that's what i want for the phone, because once i've found a wifi spot, i want to be able to find the optimum place to be to get a good signal, at home there are loads of dead spots for our home wifi, and the nokia wifi finder is useless to let me locate a good spot, as it'd take me days to find them having to wait a minute between scans.
Any suggestions?
