N95 - 8GB - battery status level is always 100%
13 replies · 12,871 views · Started 30 December 2007
Hello,
I'm using a N95 - 8GB (RM-320 - fIrmware 11.0.0.26).
I noticed the battery status level is always at 100% (for 12 hours now). I've been using bluetooth, umts and wifi during the past hours but no changes still 100% ....
I downloaded nokia's "device status" application but this shows 100% too.
This problem is very annoying as you do not know how long the battery will last.
1) Is this a known bug?
2) Is an application available that is able to show the real battery level?
Thank you very much!
yeah mines does that, 100% then the next thing ive got 1 bar and a low battery warning it seems to ignore everything in between im running V20 software
clive1 wrote:yeah mines does that, 100% then the next thing ive got 1 bar and a low battery warning it seems to ignore everything in between im running V20 software
The OP has an 8gb N95 not the N95-1 you have, even with V20 firmware.
I have the 8gb model and I check battery status on the main screen and the bars do reduce over time depending on the apps I've been running.
I dropped my daughter off in Leeds today and for fun used the GPS there and back and spent a couple of hours with her in Leeds. The phone stated with 6 bars and by the time I came home it was down to 4.
I also have Nokia device status and next time the bars drop I will check what it says.
BTW clive1 your issue is a known "bug" on the N95-1 although I thought the V20 update helped with battery life by using demand paging like the 8gb model.
Depends on the apps you have open I suppose.
:tongue:
yeah the battery life is alot better but the indicator is useless 😊
I was laughing when I read this....
The N95 was battery down within 12 hours...
Your N95 8GB (and mine) stays always at 100%...
Why the complaints?
LOL
Berty wrote:So your battery is full then!
Yes, it was! :redface:
48 hours later, having bluetooth running for more than 14hours, it is now at 57% (taken from Nokia's "device status" app).
The battery status level is also shown correctly ... This is really nice, I thought battery life was much shorter. 😊😊😊
dda wrote:Yes, it was! :redface:
Yes, the battery life on the N95 8GB is astounding. Far, far better than the 25% extra capacity you'd expect from the battery specs. So they've obviously used some different components inside etc. And this is all with twice the RAM having to be powered, plus a bigger screen - very impressive.
Steve
On screen it now shows 4 bars and in device status it it is 71% so I suppose it works LOL!
Never had a problem really.
Anyway good night, god bless and may your god be with you and have a happy new year from me and if you are in Sammy Platts 2 morrow near Old Trafford I'll be the one showing off the the new phone LOL!!!
I occassionally have issues with my battery meter level on my 8GB N95. As mentioned, sometimes it reads full then suddenly gives the low battery warning. It's not too much of a problem, as it doesn't always do it, but still annoying! 😞
