Hey Guys,
When I try to copy items from phone with the use of Lifeblog application I always get the error: "You have an incompatible version of Lifeblog on your phone".
I assume the problem has appeared after firmware upgrade to the newest one.
Should I upgrade PC Suite application as well? Where can I find the newest installation?
Thanks in advance for any hint.
slawmilcz wrote:Hey Guys,When I try to copy items from phone with the use of Lifeblog application I always get the error: "You have an incompatible version of Lifeblog on your phone".
http://europe.nokia.com/A4144903
Hey,
I have installed the newest version from the link above.
Additionally, I have forced PC Suite to install MSync to phone again... and no luck. The same error information appears every time I try to load items from phone.
Any other help?
I'm getting the same problem would be grateful if there are any others who can help. I really want to sync my LifeBlog.
Anyone could give a clue?
Could you please give me more details about your PC/Mobile and Version of the PC suite you are using? Have you installed Nokia Photos on your PC? What all are upgradation you have done in the past and from when you are facing this issue? :con?
Also please provide the version details of your Lifeblog installed on your PC too? :con?
