Hi there,
I thought after getting the N95 8GB I didn't had problems with 2 many installes apps...
But now - again - the application manager won't show all the installes apps and jar's.....
When I delete it won't leave the list, but only after shutdown and power up ...
What 2 do?
I have over 80 mb RAM left....
It doesn't really have problems, sounds like you are installing applications to the wrong location, did you put them on the 8 gig drive?
dchky wrote:It doesn't really have problems, sounds like you are installing applications to the wrong location, did you put them on the 8 gig drive?
Yeah mate!
Almost 96 % of it...
I installed 52 full apps in total..
mayB there is a bug in one of them conflicting with the processor
