Knackared 6600.
4 replies · 1,833 views · Started 02 January 2008
Hope I got the right section here, but I'm having trouble with my old 6600.
I tried to install a program called WmouseXP on my phone, then everything became sluggish, and a message appeared saying 'system error'. The phone then refused to do anything, even after startup, when I click on menu it waits 10 seconds or so, a white screen flashes and then I'm stuck.
I am able to enter numbers, but it takes a while for the numbers to appear, and that's what I'm limited to.
It's never been too reliable has my 6600. It's slow, *heavy*, and the OS is awful. But it's the only phone I have, and I can't afford a new one!
Any help is really appreciated, I need it back online asap!
Cheers.
Right now it's completely shagged.
I'm going cat hunting.
I've got "Phone startup failed. Contact the retailer" on screen now.
I hv got dat msg 4 abt 7~ 8 times now but at last i hard formatted(call button + * + 3) it and now it perfectly doing well
uninstall the application which you feel is not needed or use FE Explorer ot kill the tasks in background if it dont work try *#7370# for soft format...
