With the advent of cheap and/or unlimited data plans, good coverage and the increasing presence of Internet radio stations, the importance of listening to streaming radio stations have become much bigger than ever. In this Bible, I mostly elaborate on practices that
[LIST=1]
[*]may make the sound quality much better using the same bandwidth, and/or
[*]may save you tens or hundreds of bucks a month by heavily reducing data usage, while providing the same (or even better!) sound quality should you not be able to access any unlimited data plan (Canada with its ridiculous data rates comes into mind), and/or
[*]may heavily increase your battery life by letting you �falling back� to the much more battery-friendly 2.(7)5G Internet access technologies instead of the power-hungry 3(.5)G ones, and/or
[*]in cases, may even let you listen to some radio stations you would never have thought of because of the network / operating system restrictions, and/or
[*]makes the central administration of your radio station favorites much easier � no need to switch between different radio programs if there�s a difference between the protocols / formats they use.[/LIST]
This article is part of my �Multimedia Bible� series and will, eventually, be incorporated in some way in the final version of Multimedia Bible, which, hopefully, will be published this month. Note that I'll also elaborate on TV (video) streaming and transcoding in a later Bible. We�ll use many of the tools / technologies introduced in this Bible in there; most importantly, Orb and VLC.
This Bible, as with my last multimedia-related articles, multiplatform. Don�t get offended by this if you're a fanboy of either of the platforms and just hate everything related to the other: both Windows Mobile and Symbian software developers need to know what the other operating system offers so that they can improve on their products. In addition, should you have devices of both operating systems, you'll be able to optimize the usage of these devices. Just an example: I mostly use the Nokia N95 as my main entertainment and light Web browser / mailer / communicator device because of its, compared to any Windows Mobile device, superior A2DP quality, built-in, stereo speakers, acceptable battery life and lightweight (120g), small body. Therefore, when I know I won't need a Pocket PC (and its high-resolution VGA screen), I know I can safely leave my comparatively heavy and "brick" HTC Universal at home, and go to, say, a quick walk with my N95 only. And, of course, when I do know I will need a Pocket PC and/or a high-resolution screen (for example, to do some serious (!) Web browsing or remote desktop access/control), I take my Universal with me too. (For phoning purposes, I still use my HTC Oxygen (s310) WM5 MS Smartphone because it's cheap - no problem if I'm robbed / it's stolen -, very sturdy and is one of the very few Windows Mobile devices that support flawless, two-party call recording capabilities. I always keep it in my trousers' pocket.)
Note that I planned to review the Palm OS as well. As, currently, I don�t have a Wi-Fi card for my Tungsten T3 and I just couldn�t make it use an external IrDA / Bluetooth modem (unlike with my old Zire 71), I couldn�t test streaming on it. By the time I publish the final Multimedia Bible, I�ll try to get hold of a Wi-Fi card and update this Bible so that Palm OS is also covered. (Sorry, I can't affort a 750p just to be even more multiplatform. If you have one lying around unused, of course, you can send it to me, particularly if you're inside the EU to avoid customs issues 😉 ). After all, on Palm OS, Pocket Tunes is a freaking good audio player well worth comparing other mobile operating systems to.
Introduction
While trying to listen to a radio stream, you surely have run into not being able to play back an Internet radio station either entirely or without severe quality and/or battery life degradation. After you read this Bible � and digest all its contents �, you�ll know how to fix problems like these.
1.1 When it�s completely impossible to listen to a stream...
First, let�s take a quick look at what can cause your handset to not be able to play back a particular Internet radio station.
[LIST=1]
[*]Your connection speed simply doesn�t suffice for correctly playing back the stream. For example, you�re trying to listen to a 64 kbps (kilobit per second; that is, the so-called �bitrate�) stream over a standard GPRS connection. That is, your Internet connection speed is no more than 43 kbps. In these cases, you simply won�t be able to listen to the stream without severe pauses / stuttering, no matter how large buffers you use.
The situation is the same when you try to stay away from using a 3G (either a UMTS or a HSDPA) connection. Even if your handset supports 3G and you also have the necessary signal, you may still want to opt for disabling 3G entirely and going back to using GPRS. The most important reason for this is the vastly increased power usage of current 3G modules used in recent, even high-end handsets like the Windows Mobile HTC Kaiser or the Symbian Nokia N95 or N82. I�ve elaborated on this problem (with several tools that help in switching) in THIS (Windows Mobile) and THIS (Symbian) article.
In these cases, you will want something to (in cases, radically) decrease the bitrate of these streams. Fortunately, it�s in no way impossible. With current technology, you can transfer FM-quality, stereo music even at 24 kbps. I�m not kidding!
(Note that, in this Bible, I assume you only have GPRS access. Unfortunately, many GSM operators still stick with the GPRS + 3(.5)G schema, leaving out the 2.75G technology, EDGE altogether. One example of them is Vodafone, which, with their unlimited data plans, only support GPRS, UMTS and HSDPA / HSUPA. That is, no support for EDGE at all - at least here.
EDGE has both (for radio streaming at least) good speed (236 kbps at most) and low power usage - according to my benchmarks, it doesn't use more power than GPRS.)
[*]You�re trying to listen to a so-called �RTSP� stream but your mobile phone operator doesn�t support direct Internet connections. They use firewalls and NAT�ing (Network Address Translation � see THIS article for more info on the consequences), making it for the radio server to completely impossible to connect back to your handset. Unfortunately, about 60% of the world�s GSM operators do so.
Unfortunately, several radio stations or applications use RTSP. Most importantly, all (except for Mplayer on Windows Mobile � more on this later) mobile RealAudio players use RTSP on both Windows Mobile and Symbian. This means you simply can�t listen to radio stations utilizing RealAudio unless you�re lucky enough to have a data subscription at a mobile operator not using NAT�ing.
(Speaking of the Windows Mobile port of Mplayer, it uses the firewall / NAT-friendly HTTP protocol instead of RTSP. However, it�s a real CPU hog: in the current version, RealOne streaming only works on 624 MHz Xscale CPU�s because it�s really-really CPU-intensive and, on these CPU�s, it chews through the battery really-really fast. It can�t be played back on current, TI OMAP-based Windows Mobile models at all. All in all, it�s pretty much useless.)
RTSP is also very extensively used by Orb, one of the best tools to transcode Internet radio stations. More on this in the Orb-related section.
[*]There are simply no players to play back a given stream type. Then, even if you have a quick connection and/or a non-NAT�ing network operator, you still won�t be able to play back the stream.
The most important case of this are Windows Media Audio (WMA) streams on Symbian. While the built-in Music Player supports playing back local WMA files, it can�t do the same to WMA streams. The situation is particularly bad because the well-known, excellent Orb service, currently, only uses WMA as the only non-RTSP stream format. As WMA streams aren�t compliant with Symbian, you simply can�t use the otherwise excellent Orb if your connection is NAT�ed.
OGG stream support isn�t particularly good on Symbian either. Oggplayer is pretty much a joke and additional radio stations are pretty complicated to set up in the commercial LCG Jukebox, the only other, SHOUTcast OGG-compliant player on Symbian. (Note that CorePlayer is able to play back WMA and OGG streams but, currently, as of the current beta version, its networking module is so bad that it�s unable to play back anything without severe problems surfacing after some minutes at most. This applies to not only WMA, but also other streams. Hope future versions - hopefully the forthcoming 1.2 - fix these issues. In the meantime, stay away from it.)
[/LIST]
