I've been exploring the phone and find out that in Z:\System\T9Ldb\
are stored the files needed by the phone to run T9Dicctionaries correctly.
By default these are the files that come with the 7650:
english.rsc
french.rsc
spanish.rsc
t9english.dll
t9french.dll
t9spanish.dll
My question is, where can I find german and catalan support? If I'd copy german.rsc and t9german.dll would the phone by ready to support german ?
Once I owned a Psion Series 5 and the trick to add files to ROM or "overwrite" files in ROM was to copy them to the same directory on your C: disk. So copying these german files to your C: disk might work... If so I like to have spanish and french.
One other thing: is it legal to exchange these files?
HI!...
i have this defaults...
english.rsc
french.rsc
german.rsc
t9english.dll
t9french.dll
t9german.dll
If you want just to interchange... to test or see that files..
i can send you my german files and you please send me the SPANISH files! i need that! 😃 really...
my email is: [email protected]
thanks!
i'll wait your files to send you back mines..
cya!
Alejandro
HI!.. it's me again...
May be creating a new dir on C:\System\T9Ldb\
and puting there the new files like german.rsc and t9german.dll...
tha system recognize the new dictionary... just a theory but to test
that i need a new files... send me please the spanish ones.. and i send you the germans...
[email protected]
thanks!
Alejandro
Once again: remember that if you copy files from z: drive to c: drive they don't work!
I've copied the files in C:\System\T9Ldb\ but it doesn't work.I'll keep investigating.I remenber I saw a language.ini somewhere in the phone...
Not likely to work that easy, if at all.
But good luck with your experiments 😃
I've found something new.
File:
C:\System\Data\T9UDB0f.DAT
I can't open it with phone's notepad aplication, if someone can upload it or send it to me by mail I'd apreciate it.
I think it may be custom words database or something, I wanna make sure... 8)
Its just the database for your own words in t9
You can look for it in the backup (if you have made it) 😃
