I remember on the old communicator, i was able to copy all the text in the Excel document.
The reason i am asking, is that i have 9000 mobile numbers that i have to add to my mobile phone (to a seperat group) so how is it possible to do? because i really cant find a solution 😊
I've posted one answer before to someone who wanted to transwer 12000 contacts on his E90. I would like to suggest you the same thing. Dom't do it!. I believe that those 9000 contacts are business contacts and they are important for you but for that amount of data none of the PDA's available at the moment are built for. The E90 is a wonderful assistant I lknow 'cause i have one too and i use it to manage my business at any time anywhere, but I put only the most important contacts on my phone with pictures and everything. The rest i keep on my pc and ont he internet. From the net(gmail) and/or my PC i can access all my business contacts when needed. This is fair enough for me and the E90 is an excellent partner in doing this.
I suggest you to organize your 9000 contact list or instead of struggling with excel you can import that list on your pc to outlook and then transfer them on your phone with PcSuite.
Cheers,
