Lens Protector for N95-3
0 replies · 2,161 views · Started 03 January 2008
I have a simple solution for a lens protector for the N95-3. First buy the crystal case for the N95 8GB. You wont be able to use the front cover, but you use the back cover as part of the lens cover solution. Then buy the wide Post-It note page flags (or some other brand like Office Depot). The wide size will cover the opening in the crystal case. When you want to shoot pictures just pull it off and stick in elsewhere on your case. Reapply it when you are done. When the stick-em gets weak, just put another one on! Cheap solution for a much better N95.
