hi sorry im new to the nseries. well i have a nokia n95 8gb and i want to install the emtube but its not alowing me to it says its becuase off the secriuty certificate but is there any way i cant change that? thanks
hi how to install?
try the install .. again .. then change the date back.
I'm not sure if that was the issue with this program ..
Good Luck!😊
thanks i sorted it out now could you recomend any good free software thanks
marmaduke80 wrote:thanks i sorted it out now could you recomend any good free software thanks
Have a little hunt around these forums. There are a few threads about good free applications and games.
yeah, and check the front page of ALLABOUTSYMBIAN. 😉 Its full of good stuff 😉
thanks guys im looking now so far all i have is emtube i guess everything thing on here is virsus free 😊
marmaduke80 wrote:thanks guys im looking now so far all i have is emtube i guess everything thing on here is virsus free 😊
hi is fling safe to use? because it said something about it may not allow my phone to make calls
Yes, this isnt some dodgy forum site posting all sorts of virus riddled warez and cracks.. 😉 Its 'mostly' tested by the members and coming from established sites. SO long as your sensible, your safe.
