Email app for my Nokia?
6 replies · 2,077 views · Started 05 January 2008
I love my Mobile (a Nokia N95) but I really want "proper" push email so I can get my work emails on the fone.
I've found one app which I intend to trial which I <more spamming links!!> and seems to work on any mobile,
Worth a try??
Has anyone got any suggestions/recommendations?
Alison 😊
go to download from your menu after productivity and there is application push email (i think its freeware) so u can download directly to your phone.
I just use the inbuilt email
Gmail is IMAP for example.
For HTML use Profimail.
I thinkt his is an area where Nokia are good ats upport bu tneed to have a built in html client 😊
Does your work use Exchange? If so then Mail for Exchange 1.6.1 is good and free (though doesn't do folder support). Or Road Sync which is paid for but does support folders.
I used Profimail on IMAP (paid for) for my company mail (through Google) and Mail for Exchange for email at a client site.
Neil
Hi all,
I have recently been using the Seven all always on Beta push E-Mail app that can be got from here
http://community.seven.com/forum/main.php
Registering is easy and so is setting up the app and it supports lots of ISP's and now includes Hotmail/MSN it sets everything up for you all you need is to enter your user name and password. It also has plenty of options as to what hours you want the E-Mail pushed between and different settings for Weekends. It as also has a range of options as to which connections you want it to use or not, i am actually so impressed with the app that when the Beta ends i would consider paying for it.
Marc
Thanks guys and gals for all the advise :icon14: 😊
Alison
