trying to configure eventcore to work under 9210 & demo
4 replies · 2,693 views · Started 27 January 2003
Ok when i run core.opo i get CORE\INIT_SETUPSENDASKEYSANDMENU error. And this is solved by following one of the firmware post. but i need to get into the code core.opl to do this. but how do i open it everytime i goto filemanager and open core.opl (core) it opens in word.. and when i run program(dev) and goto open and point to the dir where core.opl in held i dont see the file how do i solve this problem.
same thing happens in demoopl for me
thanx
I have the same problem :s What I did was, I opened the file in word, copy pasted it in 'program' and re-saved it. It works after this.
Also try programming OPL from your desktop PC it's way better (faster) 😊
yeah daz i tried that but the opl file has wired chars and the indents are all weried
so its sorta rooted 😞
anything else i can try
This is a problem between firmwares I think. If I recall you need put the command RETURN on the line after the LOCAL declarations so the commands in this procedure are not called.
I'll confirm this at home tonight, or hopefully someone else will remember the exact fit
thanx ewan... i read one of the posts and it did say somthing about the firmware... ok if i have prob wit the firmware like i said i cant open the core.opl in Program(opl dev) to edit the code. it will open in word processor... how can i fix this up also thanx guys
