N70 fw 5.0737.3.0.1 auto keypad lock
4 replies · 9,753 views · Started 05 January 2008
just notice my brother's new n70me can auto keypad lock without installing any app.
it's lock after 1 minute but can't find how to set to the different time
can anyone give some suggestion?
It should had some sort of lock application. Try search on process, and shut down that process. Otherwise, only with phone format, to remove that software.
thanks
but i didn't install and can't find such app. in my own
anyway, i 'll try to hard reset later to check it out
just want to know if there's s/b use this fw found s/t like this or not
Install FExplorer, and search for processes... See if it have one with lock, or autolock, on name.
