differences with My Videos and Gallery?
2 replies · 2,569 views · Started 07 January 2008
Why do i have two places for videos?
If I bluetooth myself a video and save it it goes into gallery. What if I want it in My Videos instead how do I move it? And i only want to see the video in My Videos and not in the gallery as well?
Also when I do a memory search it doesnt show the videos in My Videos up..
P.S what does the little sheild mean next to some videos?
so is it the case of any files sent via bluetooth that go into messaging inbox and are saved will be saved to both gallery and my videos and the only way to save to my videos only is to drag and drop using windows?
You can move it using the phone browser in PC Suite or the file manager on the phone. The alternative folder to My Videos is Video Clips, ie, there's not a folder called Gallery.
The difference with the My Videos folder is that the position of a video is saved when you partially watch a file so it's ideal for longer clips or whole films.
Halon wrote:You can move it using the phone browser in PC Suite or the file manager on the phone. The alternative folder to My Videos is Video Clips, ie, there's not a folder called Gallery.
thanks for that.
If you save them to videos that you can view in the gallery they are also seen in My Videos but not the other way around.
