Can I rename photos?
8 replies · 2,534 views · Started 07 January 2008
Hi All
I have a N95 with V20 firmware
I can not find how to rename a photo once I have taken it.
Is it possible??
Gary
sure you can rename, use the file manager, Applications - Tools - File mgr, find the photo you want to rename, scroll through options and select rename
Try:-
Gallery > Images & video > (selewct photo you wish to rename) > Options > Rename
Hope this helps.
[email protected] wrote:Try:-
Hope this helps.
Thanks but I dont have the Rename option in the menu.
Does anyone else have this with V20 firmware??
Gary
Try turning the phone off and on, I had a issue with the gallery but turning off/on cured it
Yeah I have the option on my v20 fw. Open the image you want to rename in the gallery, press options, and Rename is between Edit and View details.
yeah, you have to actually open the image to rename it... not just preview it..
surfshag wrote:Thanks but I dont have the Rename option in the menu.
Hi Gary, you cannot rename the photo from the "carousel"-type display.
You must select the photo so that it shows full-screen, then you will have "Rename" under "Options".
Edit: Sorry Kontraband, crossed posts!
Thanks for all your help.
You are all right if I open the photo the option if there.
How stupid do I feel.
Thanks again.
Gary
