Hsdpa ?
5 replies · 2,120 views · Started 07 January 2008
what does the hsdpa tab do on the phone, ive had it on "when needed" and nothing else, i,ve since switched it to "when available" but i have no address in the box below.
what does it do with these settings and what am i likely to acheive
cheers
wayne
its just a faster connection when avalible you will see 3.5 on the signal level
i dont know the tec side of it
hope this helps
Switching to 'when available' will hammer your battery life, so switch it back to 'when needed' unless you are constantly using t'internet.
Steve_R wrote:Switching to 'when available' will hammer your battery life, so switch it back to 'when needed' unless you are constantly using t'internet.
3/3.5g will only hammer your battery if you stay in very marginal coverage areas for more than a few hours. If you live and spend most of your life in the city, then just leave it set to use everything - you wont notice much difference at all in battery life.
where is the HSDPA tab for this option? I havnt seen it on my n95
