In attached picture, there are folders and files I copied across to install Tom Tom 6 on my phone.
Everything woks perfectly
And I was just wondering if I can delete some of installing files from the card.
(eg. as if you install some soft, you can then delete setup.exe)
I do have a back up on the computer and I would appreciate some extra space on my card.
Cheers
