How to change the fonts
3 replies · 4,482 views · Started 08 January 2008
you know the way to change it..?
I couldn't do it..
I guess maybe it's because of the newest firmware I've updated..
I tried many times before, but still.. it didn't work..
Find this app:
FontRouter[1].LT.for.v9.Build20071109.unsigned
1) Install in the memory card.
2) Create a folder in memorycard at data en name it fonts (when there is allready one don't bother, there should b a file there called fontrouter ini
3) make fonts (choose a ttf and copy them 3 times so u have 4 fonts.
4) Rename them in2:
nohindisnr60
nohindissb60
nohinditsb60
S60ZDIGI
Now 4 the hard part...
5) make sure your cell doesn't use the memorycard (otherwise the mass storage won't work)....
Think about the message setting and change it in2 phone memory...
6) Connect with mass storage and rop the 4 files in the e:data/fonts
7) Unplug and reboot...
8) That's it....
When U want 2 change it, that's even harder.
Because the new fonts R being used by the memorycard, the mass storage won't work anymore. U can't delete the without mass storage....
1) Use the app X-plore and search 4 the frontrouter.ini file in the same folder.
2) Edit the file and change the setting on the 12th row:
enable=1
in2 this:
enable=0
3) save it and exit...
4) Reboot (this will restore your normal font)
5) Now use mass storage (again everything exits on the memorycard) and rename the folder fonts (E:data/fonts) in2 font (so loose the s)
6) Delete the files in there
7) Reboot and that's it.
When u want 2 change them at point 5 U have 2 drop the new ones in there after U deleted the old ones.
Then use X-plore again and edit the ini file and change it back 2:
enable=1
reboot and U have new ones....
Good luck.
