Net access through mobile
3 replies · 2,154 views · Started 08 January 2008
Hello,
I have a Nokia N73 on 3 pay as you go.
If I buy a �5 internet add on for my phone can I access the net through my laptop?
How is this done please?
Thanks.:icon14:
Pretty sure that on PAYG the internet add on that you've bought applies to WAP.
WAP is internet for mobiles, and allows u to browse WAP sites that are only compatiable with mobile phones.
So if this the case - in short - no.
However you can browse the internet on your phone by using the phone as a modem (not sure if ur phone doubles up as modem, but most do). Basically u connect the phone to ur laptop, and u can get dial up internet on your laptop.
But its very slow and a very expensive option on PAYG and only really sutiable to use if ur only looking for a way to access your email.
I can get 3g access with my add on if that makes any difference.
I also have the nokia software suite which allows you to connect but I dnt know the settings or if it will work with 3G.
Added the net add on and tried it last night using the Nokia software and selecting 3 UK. I left the username and password blank and it dialed and connected but dropped the line as soon as it connected.
Any ideas please?
