I just got my N95-1 yesterday with the V12 firmware, I decided I wanted to get some Chinese language support so I used NSS to change my phone from
0548763 (USA) to 0534832 (HK), updated the flash to V20..
Now the entire thing is in Chinese.. my skills are sadly lacking..
So I found 0548445 which has English/Chinese I would like to try. I used NSS once again to set the Product Code. But the software updater will not reflash the phone again.
Do you guys know a way this can be done? Or do I have to wait for a new firmware before I can try this new code?
Thanks a ton guys,
It's possible that maybe V20 isn't available for the English/Chinese product code you chose. If it says that it is, the Nokia Software Updater should give you the option to reinstall the firmware onto your phone.
Yes, it is what zxon said... V20 isn't available for your product code that you are using. If you want to go back to just english try the EURO1 code, that has V20, so it will let you do a re-install
for all language packs as far as I'm aware ... you probably just need to go into Tools / Settings / General / Personalisation / Language (2nd from bottom) 語 or 语maybe one of the characters you will see there .. click .. should be able to change that to English.
Good Luck!😊
